Re: Drain clog fixed, should regular chemicals be used to maintain?
Posted by PW on April 08, 2004 at 14:18:45:
In response to Re: Drain clog fixed, should regular chemicals be used to maintain?
In our commercial area we have good success with enzyme treatments to keep fats cleaned out of our lines. I would not expect Rid-X to give the same performance. If you are badly clogged, the jet cleaning is good advice.
: My drain was clogged, I used a long snake in the main pipe and that fixed it, now all drains flow well. Over the years it will slow again like it always does. Do you suggest to put chemicals in my system as regular maintence to keep it flowing properly, if so, what chemicals? My house is over eighty years old. Thank you
Replies to this post
There are none.
