| Posted by Jason on April 08, 2004 at 14:07:55: | |
| In response to On the safe side | |
After doing several searches on news sources on the internet and not finding any stories of water heater explosions, I am going home and remove the water heater completely just to be safe. After reading this I do not believe it is something I want to expose my family to, after all water is as wet whether it is hot or not. I must have been a fool, 90% of the time the water heater was used my family has been close to it. But, I would have thought, if one was going to have a water heater, the best time for it to blow up would be while on vacation. : : Just read a post from Sylvan regarding the possible dangerous condition that exists if a hot water heater is left on for a long period of time without using it. : : I will be away for 2 weeks during an upcoming vacation. Is this too long to leave the water heater idle? : : The unit is a GE, 50gal.,gas fired with an expansion tank installed. The book indicates that the temp. setting could be turned down to VACATION for extended periods of time. : : Which is my best option? : : Thanks in advance! : 2 weeks you should be fine on "vacation " setting as usual HJ is off base as usual. : Lowering to vacation is not just used to conserve fuel it is a safety factor. : Lets think for a minute as a boiler/pressure inspector. : You have an expansion tank possibly a bladder type and like all mechanical it is subject to failure. : Now you didnt bother to lower your temperature setting and the heater calls for heat and your expansion has become water logged. : Let me ask you WHEN was the last time someone actually tested your T&P? : What happpens in a run away firing condition if the controller fails? : : Saving energy is the least of it. : Would you leave your stove on full blast if no one is home for two weeks or a pot of boiling water on a stove? : So why leave a flame under a pressure vessel? : WHEN you come back from vacation RUN THE WATER making sure no air is present in the H/W lines THEN turn your flame to normal. : HJ PLEASE READ THE NBBI dang Guy what is wrong with you??
