Re: Drain clog fixed, should regular chemicals be used to maintain?
Posted by Sylvan Tieger on April 08, 2004 at 14:05:20:
In response to Re: Drain clog fixed, should regular chemicals be used to maintain?
: My drain was clogged, I used a long snake in the main pipe and that fixed it, now all drains flow well. Over the years it will slow again like it always does. Do you suggest to put chemicals in my system as regular maintence to keep it flowing properly, if so, what chemicals? My house is over eighty years old. Thank you I would try calling a plumbing/drain cleaning contractor and having these lines "water Jetted"
Replies to this post
There are none. |
