| Posted by Sylvan Tieger on April 08, 2004 at 13:06:00: | |
| In response to T&P in lieu of tank | |
: : : : : : I can definitely relate to one point you make here--about the the typical house has become a closed system due to the changes in the mains you mention. Out here ( So. Calif.) the codes do not require an expansion tank; but in the last several years I have noticed it is very common for pressure buildup to become a problem when a new water heater is installed. My theory is that it was a problem with the old heater, but the T/P valve was frozen shut with mineral deposits, so the problem was not noticed. I now always recommend an expansion tank be installed.
this way your accounts still know your around plus you get a service call for the T&P replacement which is a good idea when you know minerials are present to reduce its operation
