| Posted by Sylvan Tieger on April 07, 2004 at 16:18:56: | |
| In response to Re: re-packing an abs to cast iron connection | |
: I'm replacing a 16" cast iron riser to a toilet with abs. I'm told it's OK to use okum with mortar in the old cast iron hub. : What is the proper amount of okum to pack onto the joint before I seal it with the mortar? I'm guessing I should leave about 3/4" space above the okum for the mortar. Is this right? Where I come from we are not allowed to use lead wool or motar as both of these products can seep and promote bacteria growth. Personally I would use coming out of the hub a caulked joint and a short piece of CI and then an adapter to the CI like a Mission coupling. Or remove the hub completely and continue from there using a Mission CI x plastic coupling NO way would I use a Fernco coupling or mortar in a joint. Think about the fact you may get a stoppage and you do not want to take a chance of a joint blowing out. |
