| Posted by hj on April 07, 2004 at 00:59:04: | |
| In response to Re: sump pump emptying into ejector pump | |
I did not tell him to do it, but if you bothered to read it, told him it would probably be illegal, (although it was the standard way to do it in Chicago all the time because we had combination sewers). However, if he was going to do this possibly illegal thing, then at least do it in a better way. : : It would probably be illegal no matter how you did it, so why not just connect the sump pump directly to the sanitary piping rather than into the ejector basin? : HJ What planet or swamp do you reside? : Do you know about plumbing drainage at all? : Ground water is not supposed to be pumped into the"Sanitary system" but into a system : SCHOOL is in HJ READ about Fixture Unites (7.46 gallons or pumping 1 GPM : What kind of trap did you suggest Mr. HJ? :
| There are none. |
