Re: sump pump emptying into ejector pump
Posted by Sylvan Tieger on April 06, 2004 at 12:35:11:
In response to Re: sump pump emptying into ejector pump
: It would probably be illegal no matter how you did it, so why not just connect the sump pump directly to the sanitary piping rather than into the ejector basin?
HJ What planet or swamp do you reside?
Do you know about plumbing drainage at all?
Ground water is not supposed to be pumped into the"Sanitary system" but into a system
SCHOOL is in HJ READ about Fixture Unites (7.46 gallons or pumping 1 GPM
What kind of trap did you suggest Mr. HJ?
PLEASE if you do not know do not give bad advice as you really show your ignorance, why not leave advice to the real professions and stick with your handyman mentality on fixing faucets and possibly toilets
Replies to this post
