| Posted by Sylvan Tieger on April 04, 2004 at 17:27:02: | |
| In response to Re: Question on venting - what it should read - sorry | |
: : : What is the difference in a stack stack as opposed to a vent stack? : : A VENT STACK is a vertical pipe instaled primarily for the purpose of providing circulation of air to and from any part of the drainage system : Either one should be increased to at least 4" to prevent hoarfrost in certain areas and ideally you would want a Fresh Air inlet FAI installed 6" above grade and should also be half the diameter of the building house drain but in no case less the 3". : Hey no one said its easy :-(
| There are none. |
