| Posted by Joe on April 03, 2004 at 17:25:03: | |
| In response to Re: Mansfield Outdoor Faucet (Anti Siphon) Leak | |
: I know that this subject has been touched upon in the past, but for those that have dealt with mansfield wall hydrants, any recommendations on how to remove that assembly under the anti-siphon cap? It's made of plastic and appears to be screwed in, but only has tiny little plastic teeth that I've found very hard to grip. : Any help for this rookie plumber would be greatly appreciated. Thanks in advance I have a similar problem. You can remove the plastice part that has the plastic crossbars with a pliers or vice grips. Or, use a needle nose pliers from above and turn it counter clockwise. |
| There are none. |
