| Posted by CEA on April 03, 2004 at 13:12:59: | |
| In response to Re: Leaky Sink Pop-up Plugs | |
: : The only thing I can come up with is to get one of the old-fashioned rubber plugs (if I can find one to fit!) so she can use it in one of the sinks. The simplest solutions are always the best! Many pop-ups lift out of the sink for cleaning, so she can lift it out, use the rubber plug, and replace the pop-up when she's done. You should be able to find the rubber plugs at any hardware or dime store. Another solution that works is to close the pop-up and plop down one of those round rubber jar-lid-opener thingies over the drain...that will usually seal pretty well. Good luck. |
| There are none. |
