Re: Galvanized vs. Black Iron
Posted by e-plumber on April 02, 2004 at 16:34:57:
In response to Re: Galvanized vs. Black Iron
: I'm movig a gas line in a Southern california home and I was woundering if I could use galvanized for a couple of pieces? It would be a 3" and 6" nipple that would connect with black iron and a brass value. Any help will be greatly appreciate.
Galvanized nipples are steel nipples coated with zinc, so if you don't mind how it looks it's acceptable to do. Keep in mind that all gas work; new or relocating should be filed, inspected and approved. Have the installer double and triple check all joints.
Replies to this post
There are none.
