| Posted by Deb on April 02, 2004 at 09:55:51: | |
| In response to Re: Sink venting - in front of window? | |
: : Why does it need to run horizontal below the flood rim. Can't you locate the drain and vent to the side of the window and run a trap arm over to where you need it? : : Deb : : The Pipewench : If I follow you, I don't think I can run the trap arm to the side and pick it up from there. : The sink base cabinet is not as wide as the window, and the dishwasher is to the right side. On the left is an open shelving area. : Aside from the asthetic issue (not important here) I just can't picture any way to get the trap arm to a suitable position. : Matt These pipes should be in the wall, so it does not matter what is in front of them. |
