| Posted by Matt on April 02, 2004 at 02:18:34: | |
| In response to Re: Sink venting - in front of window? | |
: Why does it need to run horizontal below the flood rim. Can't you locate the drain and vent to the side of the window and run a trap arm over to where you need it? : Deb : The Pipewench If I follow you, I don't think I can run the trap arm to the side and pick it up from there. The sink base cabinet is not as wide as the window, and the dishwasher is to the right side. On the left is an open shelving area. Aside from the asthetic issue (not important here) I just can't picture any way to get the trap arm to a suitable position. Matt |
