| Posted by ED on March 31, 2004 at 16:14:46: | |
| In response to Re: Sanitary Tee installation | |
Assuming your pipes are in the "right" place, there should not be a problem using a sanitary tee. Make sure it is postioned so the flow opening in the tee points downward. So it drains properly. Wyes and Tee-wyes are often used in horizontal drainpipes because tees are not allowed in horizontal drain configurations, with few exceptions such as venting.
: Does this installation require a wye in lieu of a santee? : thanks
| There are none. |
