Re: How do you adjust a toilet flapper w/float?
Posted by Cyndi on March 30, 2004 at 11:03:25:
In response to Re: How do you adjust a toilet flapper w/float?
Help! I moved the float down, so the flapper opens up for a longer, better flush; but I now realize I am still getting phantom flush, just not every 5 minutes as before. When I open the tank, there are little air bubbles all over the flapper and the float and lower chain (the parts under water). Is there anything I can do to stop the phantom flush leak? Any other adjustments I can make--noting that I know absolutely nothing about plumbing and can't affort a plumber right now. I have a Kohler Wellworth 1.6 toilet, and I installed a Kohler Red Adjustable Flapper PP23648 (which is what the guy at the hardware store said to use). Any help you can give would be very appreciated! Thanks!
Replies to this post
There are none. |
