Re: How do you adjust a toilet flapper w/float?
Posted by jimbo on March 29, 2004 at 23:10:12:
In response to Re: How do you adjust a toilet flapper w/float?
: It is usually a good idea to use identical replacement parts; the Kohler Wellworth and other models do come with a float on the chain. There is a little clip on top and bottom side of float which you can pull off the chain, move the float down (for longer flush), then replace the clips. A "standard" low-flush flapper will work, but because the Wellworth is a much deeper tank than some others may cause the toilet to double flush do to flapper staying up too long.
