| Posted by harvey on March 26, 2004 at 09:00:40: | |
| In response to Re: question on running a vent | |
Thanks for your helpful infomation. Can you explain what an S trap is exactly?? I am a bit confused about this. My plumber said it will be ok to cut into the above tub drain b/c it is already vented-therefore the new sink drain will be vented once it is tied into the tub drain?? HE plans on adding a y connector and tieing in a new sink drain w/ inch and a half pvc. Is this wrong? HE is a licensed plumber so I am really confused now. I am concerned about this siphoning effect you mentioned int eh above post also. CAn you elaborate alittle bit?? thanks in advance,
