Re: American Standard Champion Tank/Bowl Gasket
Posted by Randy on March 25, 2004 at 16:43:50:
In response to Re: American Standard Champion Tank/Bowl Gasket
I too had the exact same problem with the American Standard Champion toilet tank. The tank bolts could not be tightened enough to make the mounting ribs touch like the instructions state withoug cracking the tank. I solved the problem by tightening it as much as I dare, then backed off one turn and installed a shim between the rear mounting ribs on either side of the tank and socked down the nuts again. This solved the problem of the tank rocking. By the way, I absolutely hate this toilet. It's got more glitches than an old computer.
