| Posted by Deb on March 25, 2004 at 14:32:13: | |
| In response to Re: Toilet Replacement | |
: The bolts on the old toilet are 11" from the sheetrock. Is there flex there where I can install a 1 piece Eljer toilet which calls from a 12" rough? : Thanks! Most likely, it will not fit if this is the distance to the finish wall. Did you measure from the wall or from the baseboard? A 12" rough-in is a standard rough-in. You can measure from the bolt holes to the back of the toilet, but most do not let you cheat it an inch. |
| There are none. |
