Re: Intermittent water leak from Intimist
Posted by e-plumber on March 24, 2004 at 07:22:50:
In response to Re: Intermittent water leak from Intimist
: I have a Pansonic Intimist washlet in my house and is about 4 years old. It has started leaking intermittently only when in use. Typically a few drops of ware is being noticed on the floor. The leak seems to be coming from the side of the washlet underneath the switches. It would leak may be once per 5 uses. Any idea how to go about fixing it. Reply: There could be a leak on the water line connection to the unit or the vacuum breaker may be defective and it is discharging water onto the floor after each use. Good Luck. e-plumber
Replies to this post
There are none. |
