Re: Hair-line crack in bowl
Posted by e-plumber on March 24, 2004 at 07:11:47:
In response to Re: Hair-line crack in bowl
: I have a Eljer Walford toilet with a hair-line crack in the bottom of the bowl (don't ask me how...). Water seeps out from the crack. Is there any chance of repairing this, or do I need to shell out the $$ for a new bowl.
: Thanks,
: Jeff
Reply:
The only true fix would be to replace the bowl. You may be able to locate the "bowl" only if it's a later model toilet. When the bowl is reset, make sure the closet flange is secured properly. The toilet should be set level, shims used if necessary and caulked. It may have cracked due to slight movement.
Good Luck. e-plumber
Replies to this post
