| Posted by Deb on March 21, 2004 at 16:01:18: | |
| In response to Re: thermostatic and pressure balance valves | |
: I will be remodeling our two bathrooms, and I am a bit confused about these two valves. The master bath is a shower only, and will be used by adults. The hall bath is a tub/shower, and will be used by children and adults. : Cold someone please explain what each of these valves is for, and if I should get both, or only one? A pressure balance valve operates by sensing pressure changes and adjusting the opposite flow to compensate. If someone flushes the toilet and the pressure of the cold water is less, the valves lets less hot water through to keep you from getting scalded. A thermostatic valves operates the same way, but adjusts on temperature changes rather than pressure changes. |
