| Posted by hj on March 21, 2004 at 14:42:45: | |
| In response to Re: PEX supply sizing | |
If you have any problem with it, it will probably be due to the amount of 1/2" piping you have rather than the bore in the PEX. : Hi, we live in a very small 600 sf 1 bed/1 bath house and am in the process of renovating a converted garage for more living space. We need to bring water to the garage, and I am planning on supplying water via 1/2" PEX taken from a 1/2" copper line from the main house. Currently the main house is piped entirely with 1/2" pipe with no problems with pressure loss. Will the small, occaisionally used garage bathroom be a victim of low water pressure if the PEX and it's narrow fittings are used? Thanks in advance, Adam
| There are none. |
