| Posted by Deb on March 20, 2004 at 11:40:18: | |
| In response to Re: basement bathroom | |
: : I HAVE A NEWER HOME WITH A BASMENT. MY SEWER PIPE GO'S : : INTO THE BASEMENT FLOOR. DO I NEED AN EJECTOR PUMP.IF NO, DO THEY MAKE A TOILET THAT DRAINS INTO THE WALL. SO I CAN PUT AN PVC ELBOW ON THE MAIN DRAIN PIPE AND BOLT IT TO THE WALL. ? : : THANKS TOM : The main line already has a vent,do i need another? Yes. Every fixture needs its own individual vent. The vent must be within a specified distance from its trap. This distance is determined by the code you are under--UPC is 6' max. The vent can tie in with another vent 6" above the flood rim level of the highest fixture the vent serves or out the roof by itself. UPC requires a 2" vent on toilets. |
| There are none. |
