| Posted by hj on March 18, 2004 at 23:03:23: | |
| In response to Re: Installing 'new' old radiators & zoning | |
If you are using "real" radiators, then you had better be thinking larger than 3/4" piping, and zoning will be the least of your problems if you do not install the piping properly. : I'm going to be installing cast iron radiators in an addition we're building. 5 rooms in all. Hot water heating, and I'd like to zone the new rooms and the rest of the existing house. How big should I drill holes to run the 3/4" copper tubing? Can anyone recommend a good book on the subject of zoning? Any other advice would be welcome as well, thank you!!
