: we replaced the part thar lets the water refill the tank, buu water sprays from the top whem refilling.
Reply: It sounds like maybe you didn't connect the refill tube, (small black rubber hose). It connects to the fill valve & then clips onto the overflow tube. Follow the instructions very closely and make sure the parts of the fill valve are installed properly. Good Luck. e-plumber
