Re: yet another vent question
Posted by e-plumber on March 18, 2004 at 16:08:38:
In response to Re: yet another vent question
: After reading through some posts I believe my dwv set up has a glitch. This is an 1890's 2 story house with a full basement. The 2nd floor full bath has a 4" drain line that goes from basement, straight up and out the roof. Here's the issue, the only other drain hooked into this section is the kitchen sink drain 1st floor which drops into the basement ceiling,then runs over to this same 4" drain line referred to above, and is vented with a studor vent. I'm thinking this isn't correct, and is in essence a problem if the line backs up???It does work but I'm thinking if I had to I could run this drain from the sink 30 feet over to hook up with the 1st floor bath? Reply: If I understand you correctly, the 4" drain stack for the 2nd floor bathroom also has the 2" kitchen drain tied into it. Nothing wrong with that hook up, that's actually a typical installation. Although, I would like to see the kitchen vent tied into a "real" vent instead of a AAV being used. Good Luck. e-plumber
Replies to this post
There are none. |
