Re: installing drain hose for a dishwaswer
Posted by e-plumber on March 18, 2004 at 07:08:34:
In response to Re: installing drain hose for a dishwaswer
: i have a pre existing rubber hose installed for a drain for a dishwasher. my question is can i insert the new plastic drain hose into the old rubber hose and clamp it off ? Reply: As long as you're inserting the new hose into the existing one, it should work, you're not restricting flow. What you will need to do though is insert a small piece of (1'2"?) pipe into the hose before you clamp it or else it will collapse the hose and leak. Make sure the connection will be accessible in case of failure. Good Luck. e-plumber
Replies to this post
There are none. |
