Re: Corroded bathrub spigot
Posted by hj on March 17, 2004 at 08:02:30:
In response to Re: Corroded bathrub spigot
WE could not tell you without seeing the situation, and maybe also trying to remvove them. It depends on how much pipe is accessible and whether the part inside the wall is also corroded to the point where it might break off.
: The spigot on my bathtub fell off last night because the piping behind it was so corroded that it snapped. The coupling as well as the pipes that go into the wall are also corroded. Is there a way to replace these pipes without removing the fiberglass tub? Do you recommend replacing with copper or galvanized pipe?
Replies to this post
There are none.
