Re: Pegasus Pedestal Sink Install...
Posted by jimbo on March 16, 2004 at 22:34:14:
In response to Re: Pegasus Pedestal Sink Install...
: Typically, pedestal sinks are not "hung" from brackets. The weight of the sink is supported by the pedestal. The sink is bolted to your 2x10 blocking to keep it from being pulled away from the wall. For utmost security, you can bolt the base of the pedestal to anchors in the floor. Finally, you could use silicone adhesive/caulk where the sinkk rests atop the pedestal.
If someone knocks this thing over now, you need to look for different friends.
Replies to this post
