| Posted by hj on March 16, 2004 at 22:22:27: | |
| In response to Re: baseboard heating in basement | |
Unless the house is deserted and the heat is off the pipes will not freeze. And it that is the building's condition, insulation would just delay the inevitable freezing. There are many things that you would have to modify to use antifreeze, possibly starting with a larger boiler since antifreeze is not as efficient as water for carrying heat. : I installed baseboard heat in my basement this summer. The Plumber installed a complete loop around the basement. The copper pipe is primarily behind the sheetrock, a foot or two away from the cinderblock foundation, and comes out in three areas where the baseboard is placed. I was suprised that the copper pipe was not insulated since it sits so close to the cold cinderbock. I was told it did not have to be insulated because it's underground and could not get below freezing. I'm concerned because I don't keep the heat on all the time in the basement and I don't want the pipe to freeze. Should I be concerned, can I add antifreeze into the system. What I've been doing is keeping the heat on when the temperature drops to 15 degrees or lower. Now that the basement is finished, it's too late to insulate the entire loop.
| There are none. |
