Re: Bolting the flange to concrete
Posted by Deb on March 16, 2004 at 21:17:01:
In response to Re: Bolting the flange to concrete
: I am ready to glue my toilet flange inside the 3 inch ABS pipe. The flange edge rests half on top of the concrete securely and half over the opening in the floor. Because of this, there isn't a good surface to bolt the flange edge to the floor. The vertical 3 inch ABS pipe is set in concrete so it won't budge and when I dry fit the flange on top of it, the flange rests partically on the cement floor and will not move either, let alone when I glue it to the ABS? How important are the bolts if the flange assembly does not move without them? Do not use a closet flange that goes inside of 3" pipe. This is not to code. Get one that glues to the outside of the pipe. Deb The Pipewench
Replies to this post
There are none. |
