| Posted by Theresa Deroin on March 16, 2004 at 20:19:19: | |
| In response to Re: steam radiator and pipes problem | |
: : I have a steam radiator system, I just replaced all the vent valves on all the radiators. The new vent valves I put on are adjustable. My problems are as follows: I Have been keeping track of the tempature's in each room to see how to adjust each valve, for some reason every room is getting heat except the back bedroom on the 2nd floor. On the 2nd floor there are 4 radiator's & the 3 room's avg temp of 74 degrees, the back bedroom gets up to 65 degrees & the radiator is getting warm. Can you help me on how to adjust each vent valve so the heat gets upstairs? : Thank you, : John Bolan
| There are none. |
