| Posted by Gary Swart on March 16, 2004 at 14:03:01: | |
| In response to Re: Toilet Leaking at Floor | |
: The toilet was removed four years ago for the installation of a ceramic tile floor. The installer had to get longer bolts to fasten the bowl to the floor. Now there is seepage at the front of the toilet where it sits on the floor. Is it normal to have the seal last only four years? What is the best way to fix. Thanks. No, it isn't normal for a wax ring to fail, but that's assuming all installation details were done correctly, including the flange resting on top of the finished floor. It sounds like the tile was laid around the flange so that the new floor level is above the flange probably 1/4" or so. That's why the longer bolts were needed. This space can be compensated for with the wax ring, but perhaps when the toilet was reset, the new ring wasn't thick enough. The only way to know for sure is to pull the toilet and find out. |
| There are none. |
