| Posted by spatrubles on March 16, 2004 at 11:15:58: | |
The rings around the jets of my spa tub are cracked. Also, over the past several months, a small water spot on the ceiling below the tub has appeared and is getting worse. Would the cracked jet rings cause water to leak under the tub? Are the jet rings hard to install? Finally, can I use something like Kilz to cover the ceiling spot, or will I need to replace the drywall with a patch? Any insight is appreciated?
| There are none. |
