| Posted by hj on March 15, 2004 at 22:24:49: | |
| In response to Re: Reliance 501 Hot Water Heater | |
Unless it was rewired improperly, the reset button is on the upper thermostat. If you only have one element and thermostat, then it will be on the bottom one. : Does this model have a re-set button? Mine is not heating water, and I suspect that pushing a re-set button will do the trick. I do not see such behind either panel. : Thanks, Woody
