| Posted by CEA on March 15, 2004 at 18:14:23: | |
| In response to Re: New bathroom sink leaks - Resolution | |
: Resolution: : I took the P trap assembly apart and installed a new reducing washer and a new nut and installed it again, this time tightening it snug, no more. That worked and it doesn't leak. I tightened it down really really hard the first time - which must have caused the washer to fail. It seems like less is more with the plastic screw on fittings. Must be a lot like compression fittings in that overtightening, not undertightening, can most often lead to failure. : Thanks for the help. : Greg N 50% of the time these fittings leak because they are overtightened. The other 50% of the time they leak because they aren't tightened enough :)
| There are none. |
