| Posted by Darrell Henze on March 15, 2004 at 12:54:18: | |
I'd like to install a pedestal sink in a first floor location that has the plumbing coming up through the floor. The feed lines aren't a problem. They are spaced in such a way that they come up close enough to the wall and spaced close enough to be reasonable. It's the drain that is the hassle. It comes up about 8 inches to the side of the feedlines. Fortunately I can get to the pipes through the basement so I can relocate the drain pipe "comeup location". But I can't see how I will be able to fit the necessary trap and combination of elbows to get it all behind the pedestal. Does anyone have any tricks (short of replumbing it into the wall) to get that drain to fit? It woudl seem that a flexible drain pipe after the trap might work but is this available? Is is "code"? Thanks in advance! -Darrell |
