Re: low water pressure
Posted by Sylvan on March 13, 2004 at 14:09:57:
In response to Re: low water pressure
: i am currently doing rehab on a house that has been vacant for a bit. we installed a new faucet in the bath on the second floor and there seems to be very little water pressure (already tryed the aerator to no avail). when you first turn the faucet on the pressure seems to be normal then after a second or so the water quantity and pressure slows way down. the down stairs set tub seem to have good pressure. any thoughts.
What kind of piping material is in your home (Ferrous or non ferrous)
Also you may consider flush /back flush these lines to make sure no debris entered then during construction usiing water not air pressure
Replies to this post
There are none.
