Re: Garden water spigot where well is bored?
Posted by Sylvan on March 13, 2004 at 12:48:19:
In response to Re: Garden water spigot where well is bored?
: My husband is in the process of installing a 3/4 horsepower -10 gallon pump into the new drilled well. He is learning as he goes and is vague to me (not sure) when I ask if we can have a water spigot out by the well to water a garden. He is putting in a new large pressure tank over about 75 feet away under a shed and says there will be a faucet there but I want one closer to where the garden will be . Can he put one where the water is coming out of the well and let the pump in the ground do its thing ? There is supposed to be plenty of water - 12 gallon a minute and water is only 43 feet down and it is 103 ft deep. Or will we have to bury a water pipe from the pressue tank to where the garden is. (Or deal with a hose forever?(hate it) Thank you for any advice-Lena
Any time you use a hose connection make sure it has a vacuum breaker installed also depending on your frost line where this hose bib should be located
Replies to this post
