Re: See if you can answer this???
Posted by Gintaras Kuzma on March 13, 2004 at 09:28:29:
In response to Re: See if you can answer this???
Wow, I have the same problem! I was searching on the web for ideas and came across this post, so I am hoping there is an answer out there somewhere. If I remove the cartrige and turn the water on, (so it shoots out horizontally) I can see that I have enough pressure to get a nice shower... But when I put it all back together, I get less pressure, and a shower has "tolerable" pressure. I even removed the cartrige and ran it like that, but then all I got was cold water. What gives?? I am thinking of replacing my Moen with a cheaper one that won't restrict the flow. Any ideas??
Replies to this post
There are none. |
