| Posted by ED on March 12, 2004 at 18:41:37: | |
| In response to Re: adding a basement toilet | |
Sounds like this man needs to hear your advice from more than you Deb even though you are an excellent adviser on this board! Attn: John: The three "experts" on this forum that consistently post are Deb, hj, and e-plumber. While you may get different answers they will all be the same - Now that makes a lot of sense doesn't it? They will all tell you what you are facing is MISSION: Impossible. Well OK, MISSION: Impractical. Floor drains if they are connected to the samitary sewer system or septic system have P-traps attached to them to keep sewer gas from coming in to your basement. YOU CAN NOT SET A TOILET ON A FLOOR DRAIN! THIS IS NOT CODE APPROVED TO DO AND IT WOULD NOT WORK!!!! The toilet would not flush properly because of its trap and the P-trap that is part of a floor drainage system! Does that make sense?
: No, there is NO easy way to use the floor drain for a toilet. There may not even be a hard way. I am a little confused by the fact that the drainage line exits the house 4' off the floor. Are you even sure that the floor drains drain to the sanitary sewer and not to some grey water system? If the floor drain is connected to the sanitary sewer sysem, it may be possible to remove the floor drain and adapt to a shower. It will probably not be easy, however. If the floor drains do not connect to the sanitary sewer system, your only alternative is some kind of pump system.
