Re: Heating new construction **Should've mentioned**
Posted by Hube on March 11, 2004 at 17:53:06:
In response to Re: Heating new construction **Should've mentioned**
: SHOULD'VE MENTIONED, THE HOUSE IS IN NJ : : : I'm putting up a bi-level modular with copper pipes stubbed through the floor for hot water baseboard heat. Generally speaking, is it less expensive to install an oil fired burner or LP Furnace. Only interested in the initial cost, not the ongoing costs of the actual oil or LP itself. OIL
Replies to this post
There are none. |
