| Posted by RICHARD on March 11, 2004 at 13:47:28: | |
| In response to Re: WELL TROL PRESSURE TANK | |
: : MY TANK WILL PRESSURE TO 50PSI REMAIN THERE TILL THERE IS A DRAW ON THE SYSTEM THAN WILL DROP TO 0 SHUT OFF THEN PRESSURE UP . THAN UP AND DOWN TILL THE DEMAND HAS ENDED. DO I NEED TO RE PRESSURIZE THE TANK? : : MY TANK IS WELL TROL 53133983 : : THANK YOU : I am thinking that you may have a blown bladder in your tank. Water will come out of the air valve if this is the case. As Hube said, the air pressure in the tank should be 2#s less than the kick on pressure on your switch. |
