| Posted by hj on March 10, 2004 at 22:13:37: | |
| In response to Re: glued_pvc | |
One brand is "Ram Bit". : I've got a 1.5" pvc drain pipe glued to a 3" (3x3x1.5)dwv stack that I want to remove carefully enough to preserve and reglue inside the fitting hub. I can cut the pipe flush with the hub, but need to remove the remaining inserted/glued pipe. : I can imagine carefully using (slowly so as not to melt the pvc) a 1.5" hole saw, but... : Is there a 1.5" saw or specialty tool to specifically cut out this pipe or can someone recommend a tried and true method? : Thanks for any info, : Greg :
| There are none. |
