| Posted by Deb on March 10, 2004 at 11:09:27: | |
| In response to Re: WELL TROL PRESSURE TANK | |
: MY TANK WILL PRESSURE TO 50PSI REMAIN THERE TILL THERE IS A DRAW ON THE SYSTEM THAN WILL DROP TO 0 SHUT OFF THEN PRESSURE UP . THAN UP AND DOWN TILL THE DEMAND HAS ENDED. DO I NEED TO RE PRESSURIZE THE TANK? : MY TANK IS WELL TROL 53133983 : THANK YOU I am thinking that you may have a blown bladder in your tank. Water will come out of the air valve if this is the case. As Hube said, the air pressure in the tank should be 2#s less than the kick on pressure on your switch. |
