Re: WELL TROL PRESSURE TANK
Posted by Hube on March 09, 2004 at 18:15:06:
In response to Re: WELL TROL PRESSURE TANK
: MY TANK WILL PRESSURE TO 50PSI REMAIN THERE TILL THERE IS A DRAW ON THE SYSTEM THAN WILL DROP TO 0 SHUT OFF THEN PRESSURE UP . THAN UP AND DOWN TILL THE DEMAND HAS ENDED. DO I NEED TO RE PRESSURIZE THE TANK?
: MY TANK IS WELL TROL 53133983
: THANK YOU
With the tank completely EMPTY of water it should have 2 psi less air than the cut-in setting. Hube
Replies to this post
There are none.
