Worcester 9.24 Electronic
Posted by Ian on March 09, 2004 at 15:42:24:
My cold tap has to be turned on nearly full before the micro switch detects water flow & fires up the boiler. Obviously the water is running too fast to be heated to a reasonable temperature. The heating side of the combi is fine. Do I have a problem with the micro switch or is it something else such as the diaphram in the diverter vave? Your advice would be appreciated.
Replies to this post
There are none.
