Wet venting the toilet
Posted by David S. on March 09, 2004 at 08:59:07:
Referring to http://www.masterplumber.com/Laws/UPCExcerpts.html#toiletventing
the illustration #2 on the right is approximately my situation, except my vertical run is wet-vented, and the horizontal run is under the slab. Ordinarily the wye branch near the toilet bend is positioned 45deg up from flat. However I've heard that when its a wet vent, the branch is set flat. Which way should I set this?
Also, with the direction change being under slab I can't put in that wye with the cleanout. How about 45's for the change, and a santee with cleanout port in the vertical run?
Replies to this post
