| Posted by Gary Swart on March 07, 2004 at 14:11:32: | |
| In response to Re: Floor Drain problems | |
Deb is correct. That ball is a backflow preventor. The ball floats in the water and will not cause the drain to be slow. The reason your drain is slow is because the line is clogged. Call a plumber to auger the line. |
| There are none. |
